My 500GB SanDisk Extreme Portable SSD just stopped showing up in my MacBook ProM1.
When I installed the SanDisk security app, it saw it but said there were no volumes.
It does not show up at all in the disk utility.
I have a lot of video work on this and need it working. Could someone help me, please?
Hi @illsonics,
Please refer the article ssd drive is not detected in the system:
https://kb.sandisk.com/app/answers/detail/a_id/13015
Please contact the SD Technical Support team for best assistance and troubleshooting:https://kb.sandisk.com/app/ask
If a 500GB SanDisk Extreme Portable SSD has suddenly stopped showing up, it may be due to a connection issue, driver problem, or a failing SSD. Troubleshoot by checking cable connections, updating drivers, or testing the SSD on another device to determine the cause of the issue.
Losing data can be a frustrating experience. However, there are several data recovery software options available online that can assist you in recovering lost files from storage devices. The most popular option is…SanDisk Extreme SSD Failure: Tips to Prevent from Further Damage.
