The SanDisk firmware is limited to about 6000 files. I so if you use small files you won’t be able to use all the space. With flac or higher nitrates you can.
OK I have a 32gb card, and I guess I have over filled it past the 6000 files, because i dumped a few 100 more files on it last night and then i started removeing every other one of my old files! I didnt know you could “over fill” this card and the sandisk will not reconize some of the files on the card. I have top bilboard 100 songs by yr from 1965 to 2012 (so 100 songs per yr) which is great but thats all that will go on my sandisk :( Is there anywhere around this?? a different model? This is awefull , i mean whats why you buy the space but then you cant use it?!?!
Ideas anyone? any updates to make my sandisk accept like 10,000 files? or should i get a different model and take my zip clip back to best buy?
The database limitation has nothing to do with the available memory space. It only option I see for you is to install Rockbox (3rd-party, alternative, open-source) firmware. It has no such limitation.
By the way, posting your e-mail address on a public forum is not such a good idea unless you enjoy being spam-bombed.
You can use the Options in the upper right-hand corner of your post to edit it out if you’d like.
