Can’t find an answer to this simple, probably dumb question.
1 computer, 2 sandisks, any problem downloading the same library to both?
Any way to have different libraries for each?
Thanks in aAdvance.
Thanks in aAdvance.
no problem sync 1 library to both sansas
Regarding your other question: At least with Winamp I don’t think it would be a problem having two different libraries for the two Clips, just transfer different files to them and that’s it. I assume that would be the case with any program but I only use Winamp so I don’t know.
I do this without any problems. I have a Clip and a Fuze and sync both from the same computer using Winamp. In MSC mode, Winamp put’s a little hidden INI file on each player that contains all the sync settings for the player, so it always knows which one is hooked up and what settings to use.
