1.3.2 just downloaded
I had 1.2 installed and just had a cache reset so I thought I would give 1.3.1 a try.  Low and behold I’m getting 1.3.2.
Sama as here, expresscache reset itself a few days ago, so i downloaded the new version, from now on i’ ll begin a fresh start.
Small tweaks.
Download is about the same size as previous version.
Don’t have a good feeling about this, but I will give it a go.
They should announce that it 1.3.2 is available.
@Giuseppe
The file size is about the same cause nothing was really done, lol.
nogames
What’s the verdict?
I think all your positive or negative comments should go in this thread after you have tried it out.
I have downloaded the file. I’ll do the install when I experience a cache reset eventually.
So - How is the new release working out for you?
