Updated my 8GB Clip+ to the 01.02.09 FW. Initially it seemed to make no difference to the erratic battery charge problem. However, after doing a reset (hold power button at least 15 seconds to reset), the unit appears to be behaving more as I would expect, regarding battery capacity, charging, and state of charge indicator.
Not perfect, but fairly “normally”.
One other thing I did: Turn down display brightness to lowest setting. (That’s what caused me to do a system reset, because of the known issue with 01.02.09 FW that causes a lockup if brightness setting screen is allowed to remain displayed thru an auto-display-off cycle.) Not sure if lowest display brightness setting has anything to do with battery charging etc., but I’m leaving it on lowest setting anyway.
FWIW…
