Also in Windows 7 I used to get a Sansa window pop up when I plugged teh device in to the USB and that was on auto mode. I now just get a Fuze device under My Computer or a drive mapped if I use MTP. Any ideas on this?
I have had mixed results using the Sansa Media Converter. Many users report a loss of audio synchronization, a remnant actually caused by the frame rate and the NTSC standard with analog television- with digital, dropped frames causes the audio to fall out of synchronization, but I digress.
Try using AnyVideoConverter. There’s a post regarding the specifications that seem to work well. The cool thing with the Fuze+ is that many different conversion programs will work equally well.
As to that stutter, be sure that the SDHC card is formatted with 32kb cluster allocation size , as Windows has the nasty habit of defaulting to 4kb. The smaller cluster size can create a lot of processor overhead that will lead to a stutter, both in video and audio.
Try transferring the same video file to the internal memory and see if it plays better. The read speed of the card shouldn’t be a problem, especially with a SanDisk card, for your videoto play smoothly.
SMC has a habit of generating a huge video file at times; try using an alternate engine to build the file formatted for the Fuze screen. Let us know of the results, or post any questions here!
The new screen is great for video. I have to get some more microSD cards for more movie clips, it’s a lot of fun on the Fuze+.
