"Wrong File Content"
When I try to play a certain video file on my Sansa TakeTV, it gives me an error message that states “Wrong File Content”.  The file is .avi and is playable on my computer.  This is the first time I’ve had this message since I’ve been using the TakeTV device.  Any help?
Not all .avi, Sansa TakeTV can’t support some .avi files.
avi is just a container and the take tv does not support all codecs that can be in that container. you can use a program like gspot to  analyse the file to see what codec is used in the file. then you can use a program like any video converter to convert the file to the correct format. if i remember correctly the supported codec the take tv uses is mpeg4
Message Edited by drlucky on 06-05-2009 12:58 PM
