Won't Play When Connected to Computer
This is my first MP3 player. Is it the design intent to stop playing when connected to the computer? Mine shows a firmware version v01.01.12A, if that makes a difference. – Thanks, Buttons
Whether it was designed not to work when plugged into the computer is something only the guy who designed the thing can answer, but indeed it does not play when plugged into the computer. It will play when audio connection is absent, like from an AC wall charger
Yes, it is designed to work that way. Normal operation functions are disabled when it detects a data connection. All of SanDiksk’s players have always worked this way.
