PC with Windows 10 and Google Chrome and WiFi enabled does not see the wireless MyPassport Pro 3Tb. The network window does not show its network whereas the Ipad Pro does. What is the issue?
Hi alne,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
Create a support case with our world-class service and support team.
