WD My Passport Wireless Pro, network access and files upload issues
Recently acquired the My Passport Wireless Pro and since it doesn’t work properly. I’m using windows 10.
  1. When I try to upload files with WD Access, Every time it says ''lost connection to my passport". , But the connection is stable. If I need to use a cable to transfer files what is the point.
  2. I can’t access the network folder. when I click on the Icon it opens the web page dashboard. I tried to fix it by putting all network discovery on automatic through Regedit and more. On and off I can see the My passport drive as computer but receive a 0x800700350 error code which I tried to fix as well.
Would appreciate very much any help to fix this.
Thanks
Hi Nono19,
You should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
If,during setup of MPWP you followed the instruction to connect the MPW wireless signal to your router/internet. In this case your MPW is now connected to your router and not directly to your mobije devices, PC etc. So, to access the MPW you connect to the home network SSID. It is best to have the MPW fairly close to the router and not your PC, mobile devices since the wireless signal between the MPW and router will be optimum.
