Yes. But you might also want to consider getting a basic wall-to-USB-jack charger and using your Sansa cable with it. That way you could also use the wall charger for other USB devices with their cords.
EDIT: Oops, just saw the price. Unless they have some sneaky high shipping fees, sure, that’s definitely worth it.
Thanks, the USB jack wall charger sounds like a better idea. I wanted to get the wall charger so that I would have another way to charge the Fuze incase I lost the cable that came with it but then I thought how would I connect it to the computer. I am going to buy the USB power adapter http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10420&cs_id=1042001&p_id=6171&seq=1&format=2 along with a data cable http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10832&cs_id=1083203&p_id=3489&seq=1&format=2 incase I lose the original one. Shipping is a little over $2 or I could get it the next day for $4.73
I have been buying all my cables from this site for that past 4 years. I’m surprised that this site is not more well known, all of their products are really high quality (especially cables) and everything is dirt cheap.
By the way, according to Neutron Bob:
“The AC adapter needed is 5 volts at a minimum of 200ma. I’d aim for a bit of headroom, at least 500mA, to properly charge the Fuze.”
People also use 900ma-1000ma, like the one you linked to, without problems.
