Will it break if in freezing temperatures?
My Clip Sports Plus won’t turn on after trying to charge it and hold the on button. It was working perfectly earlier today and didn’t show signs of having low battery, but then I left it in my pocket for a few hours and it’s currently in the 30s F where I am and rained a bit. My pocket isn’t the thickest, so is it because of the weather it won’t work? Are there other ways to try to jump start it?
AFAIK the Clip Sports Plus is a rather old model so it is possible it has malfunctioned.
Leave the device in a warm, dry place to return to room temperature naturally. After 30 minutes, try holding down the power button for 20 seconds to force a restart.
It’s normal for older models to experience malfunctions, but you can place the device in a warm, dry environment to let it warm up naturally. After 30 minutes, try holding down the power button for 20 seconds to force a restart.
