From the first time i tried to play videos on my sansa fuze it always has a layer of green staticy kinda stuff over the video. The audio works and you can barly see the video, can anyone help?
Try playing the same file on your PC (the one on the Fuze), you probably will see the same thing… green blotchies… Also try playing the original on the PC.
You may need to run the file thru another program before SMC (Sansa Media Converter) and convert it to some intermediate format first. This is common and happens alot with videos downloaded from the 'net.
i fixed it about 10 mins ago, nvm
Was i correct at least?
nope, i just failed to update it XD, but thanks anyways
