I was charging my 4gb fuze and the display went dark. I disconnected from computer, then display went white. I have tried resetting by holding power button, but nothing changes. I plugged it back to the computer and still a white screen.
Try setting it to Lock, then moving it out of Lock position, and then holding it in power-off position. I used to get this too before 1.0.2.26A and that’s how I fixed it back then. It would only happen if I left it plugged in overnight though. After you fix it, upgrade that firmware!
That worked. I am wondering what else is wrong with it. I had it on the computer several hours this morning and the battery is barely charged. I had thought I charged it yesterday and took it off to find it hadn’t changed at all. I thought I had the latest upgrade, but will try that tomorrow. Thanks.
