i’ve downloaded an audiobook and when i try to transfer it to the sansa, it comes up in music or i can’t find it at all, where do i put it to make it come up under the audiobooks… PLEASE, I KNOW THIS IS PROBABLY A STUPID QUESTION BUT I NEED HELP…
Try to download the latest firmware… that is the 01.01.29. there is a thread about it…
That upgrade will create separated folders for Audiobooks, Podcast, Audible (files)… so if you are in USB MSC mode you can put everything where is supposed to…
If you are sync-ing in USB MTP mode then try to change the file tag in Genre to “Audiobook” and that should do the trick
Once you have the book in Media Overdrive, click on Transfer and then choose Advanced. Choose the audiobook folder and create a new folder with the title of the book, then complete the transfer process.
