I have over 5000 mp3 files on my player. It takes over 1/2 hour to refresh the media. Refreshing media happens sometimes after disconnecting the USB cable after a recharge.
I want to have the refresh to happen on demand. I have deleted some files, connected the USB cable then disconnected it and the resfresh didn’t happen.
Adding or removing a file should not refresh the media right away. Imagine every time I remove a file I have to wait 30 minutes. This would be intolerable.
The card might help.
This is exactly how it works. Any manipulation of the files (adding, deleting, edting tags, etc.) will trigger a database refresh upon disconnecting from your computer.
The time it takes to refresh is not based on memory space used, but number of files, length of titles, albums and so on contained in the ID3 tags, etc. I too, have 40GB full of FLAC files and the refresh only takes about 6-8 minutes.
With mp3 files being smaller, you’re going to have more files for it to read, but it should still only take 10-12 minutes for a refresh. If it’s taking longer than that, you need to look at your files and the tags, because that’s what’s slowing it down.
With mp3 files being smaller, you’re going to have more files for it to read, but it should still only take approx. 15 minutes for a refresh. If it’s taking longer than that, you need to look at your files and the tags, because that’s what’s slowing it down
I am more concerned about getting to the refresh to happen when i want it to, than how long it takes.
There is no way to trigger a refresh “on demand”. It happens when the player detects any “difference” in the file structure upon disconnection from a computer. Sometimes this is from adding, deleting or moving a file or even just "reading’ the files by the host computer as during an A/V scan.
You can’t make it happen only when you want it to.
If you want to install Rockbox (3rd-party firmware) though, it will do it in the background, so you never see it happen and don’t have to wait. You can play music right away.
You can force a refresh on Sandisk players by deleting the MTABLE.SYS file which holds the database. A while back the database on one of my players was messed up, and the the player wouldn’t refresh the database after that when I changed files on it. Deleting MTABLE.SYS forced a database refresh when the player was disconnected, and fixed the problem.
