I have a WD Passport that I purchased for my PC but recently got a Mac. I went through the conversion steps through Disk Utility and now My Passport will not show up in my Finder or Disk Utility only “WD Unlocker” will. It does show up in System Information though! Please help!
Hi mackenziesimons,
It seems that My Passport drive is protected with WD Security and can be unlocked using a password. If you don’t know the password, you may try accessing its data on connecting with the same computer using previously when auto unlock is enabled, then remove the password to use it on Mac.
