Hi everyone!
Sorry to bother you with a trivial question, but I’m about to order 2 WD Essentials HDD 2.5 inches 2 Tb and 3 Tb. The model numbers are WDBU6Y0020BBK-WESN and WDBU6Y0030BBK-WESN, respectively. Before placing an order, I’d like to know just one or two things, if you’ll be so kind to help me out!
Sometimes, in the past, I had the need to remove the HDD from its case and use it as an internal SATA drive for one of my laptops (because of a disk failure or other problem).
I’m wondering if these 2 HDDs I’ve provided above, when removed from their case, are 7, 9.5, or 12.5 in height and if they have a standard SATA connector or some other non-compatible interface.
Could anyone help me in this? ![]()
Thank you very much in advance!
Alessandro
