Sorry for my english.
I want to but a WD Elements 4tb external, model WDBWLG0040HBK.
In the past I had a problem with the electric adaptor in external drive and I can’t use the inside hdd in a sata port or generic external case to rescue my data.
So, I want to know if I have any problem with the electric adaptor or with the case, I was wondering if I could get out my hdd from the case and use it in a normal sata port/generic external case, it means, are there a “normal sata hdd” inside the case?.
Thank you.
Really?.. Are there a “normal sata” inside?.. Amazing!.. Thank you very much.
Do you know any model of 2tb or 4tb with “no normal sata” inside from Western Digital?.. To avoid problems if I buy any other model.
Thank you very much…
i have also disassembled a 3TB My Book and a 2TB My Cloud … both use a Standard SATA HDD
If you look at disassembly videos on Youtube … you’ll find all the 3.5" HDD’s are Standard SATA
example … 4TB My Book disassembly video , remove the USB Controller Board and it’s Standard SATA
(2.5" External WD HDD’s are NOT Standard SATA)
So, I suppose Elements model has identical connector… No problems with encrypting things I read on forums?.
Thank you very much, you are helping me a lot.
Greetings!.
Oh!, I saw the video you told me and externally my hdd is identical with that mybook… I thought they were different devices.
Elements have no Data Encryption … so that’s ok
My Book’s have Encyption … so no, you can’t remove it and put in another case and access your files.
Read my Post HERE … i tried it with my 3TB My Book [Pictures Included]
Oh, so bad for Mybook then… So, Elements is ok for a new drive because it can be extracted from its case and used in a sata port/sata device, but MyBook can’t do this because its encyption.
All clear now. Amazing help!.. Thank you very much.
Best regards.
To clarify the “My Book” … You can do this, _but you won’t have access to your file_s.
You will have to Format the drive 1st, before you can use it in a non-WD enclosure.
Oh, yes yes I understood you perfectly… You explained it very well…
But I saw an offer for Elements 4tb model from 99€, when usual it costs more than 140€… So, I will buy now… hehe
Thank you and best regards…
I think so…
“Mad Days” in a local store…hehe “Mad money” for me…XD
PD: Greetings from New Caprica…hehe
