Hi!
First of all I hope all of you are ok!
I have a wd my passport slim 1TB (https://support-en.wd.com/app/products/product-detail/p/219). Unfortunately the hdd fell last week and it has stopped working properly since that time. Luckily nothing important was there. However I would like to reuse the enclosure, if possible. I have been trying to find other hdd compatible, but it is difficult and the problems are in the pcb interface and dimensions. Everything I find has SATA interface and not usb.
So, does anyone have a solution to help me?
Thank you!
