I have the wd ssd but i have made the internal ssd external by ssd box but my kitfox is not detecting it even though it is plugged in
@Sami786 KitFox is Western Digital (HDD) and does not support SSD drives. Please download and use the SanDisk Dashboard for SSD drives.
KitFox doesn’t support SSDs, only HDDs. Connect your SSD directly to a PC and use Western Digital Dashboard to check if it’s recognized, update firmware, and test its health. Also, ensure your SSD enclosure is compatible and properly connected.
WD Dashoard does not update firmware for Sa510 it repeatedly gives “Firmware update failed”
Thu Mar 20 16:41:48 2025 0x9972908 Critical: – Error updating firmware: “OPERATION_FAILED”
Thu Mar 20 16:41:48 2025 0x9972908 Critical: – “Unknown exception”
Thu Mar 20 16:41:48 2025 0x1ea79a0 Critical: – js: “Uncaught (in promise) undefined”
Thu Mar 20 16:41:53 2025 0x9972648 Warning: – Error getting temperature: error code: 6
error subcode: 65282
message: device error detected, status ffh, error 2h
location: C:\jenks\win32\workspace\shboard-sandisk_official_release\back_end\yadl\yextata\errors.c :: yextata_check_error (line 25)
I suggest using a machine with a fresh install of Windows and use a USB box for the SA510 to update the firmware
Most likely some driver conflicts are affecting the firmware update
After a fresh install of Windows 10 and installing latest sandisk dashboard v5.0.2.3, this is what I get
lun mar 24 05:25:26 2025 0x1ea83b8 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
lun mar 24 05:25:29 2025 0x1ea8458 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
lun mar 24 05:25:29 2025 0x1ea8338 Critical: – Error updating firmware: “OPERATION_FAILED”
lun mar 24 05:25:29 2025 0x1ea8338 Critical: – “Unknown exception”
lun mar 24 05:25:29 2025 0x1e20828 Critical: – js: “Uncaught (in promise) undefined”
lun mar 24 05:25:31 2025 0x1ea8678 Warning: – Error getting temperature: error code: 6
location: C:\actions-runner_work\ISS-dashboard\ISS-dashboard\back_end\yadl\yextata\errors.c :: yextata_check_error (line 25)
lun mar 24 05:25:32 2025 0x1ea8458 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
lun mar 24 05:25:35 2025 0x1ea83b8 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
lun mar 24 05:25:37 2025 0x1ea8458 Critical: – Error updating firmware: “OPERATION_FAILED”
lun mar 24 05:25:37 2025 0x1ea8458 Critical: – “Unknown exception”
lun mar 24 05:25:37 2025 0x1e20828 Critical: – js: “Uncaught (in promise) undefined”
lun mar 24 05:25:38 2025 0x1ea8338 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
lun mar 24 05:25:41 2025 0x1ea83b8 Warning: – PdhEnumObjectItems failed with 0x -1073738824 .
any ideas? does the dashboard still work or is it deprecated?
I have retried creating a usb stick however this also fails to update the firmware. giving the same error “Firmware update failed”
