WD Black PCIe SSD not returning SMART data
I just installed a brand new WD Black PCIe SSD WDS256G1X0C-00ENX0 drive. I cloned the existing system disk to the SSD, and it boots right up. Everything seems to be working fine, but I can’t get any SMART info from the drive.
When I run the WD SSD Dashboard utility, there’s no info in the SMART pane, just a couple of what look like broken link images. There’s nothing under “Advanced Details.” (see image)
When I try to run either the short or extended test, a dialog box pops up and says, “The S.M.A.R.T. Diagnostic Test failed.”
A couple of other interesting tidbits:
SMART Monitoring Tools shows “Unknown model,” and similarly cannot read SMART data from the drive.
Windows 7’s Device Manager thinks that it’s a SCSI drive (see image)
Any suggestions or insights will be most appreciated.
Some PC’s have a setting in BIOS for turning SMART On/Off. You might check your BIOS and see if it is ON.
SMART is turned on in the BIOS, thanks. When I plug in a SATA SSD, it shows right up with full information.
For PCIe NVMe SSD, if you are using an iRST driver the SMART is not supported, this is a driver limitation.
hi
i have the same problem regarding dashboard.
sorry i have another problem regarding registering (WD Black PCIe SSD )
for 2 days i am trying, when i enter information (always captcha and security ?!)
few days back i register a portable HD without issue.
i try to login with my email, they said your email is not in the data base , when i try to register they said your email is already there.
any help
thanks
I wouldn’t worry about S.M.A.R.T anyway. It’s really not useful at all anyway.
