volume keeps changing on it's own :-(
i have a 1gb black sansa clip. it has an annoying habit of sometimes lowering it’s volume output during the gap between songs. i normally have it on max (i play it in my car)
once the volume has dropped, as soon as i operate any button it returns to max again.
i’ve loaded the latest firmware but it still has this fault.
anyone else noticed this?
should i return it under warranty?
thanks.
had the same problem. i guess it is sortof common. i was using custom equalizer setting, changed it to normal and then the problem was gone. but it kinda ■■■■■ that i cannot use my custom equalizer setting any more…
