Hello - when playing videos stored on the 64G WMD through my ipad 2, the videos freeze, thaw, re-freeze on and on. Tried pausing until the vid file fully loaded, no joy. Tried changing my wireless connection directly to the drive, no joy. Any advice?
Yes. Never use the term “no joy” ever again. ![]()
What is the bitrate of the videos you are trying to stream? Buffering during stream usually indicates a high bit rate that the WMD can’t stream fast enough. If the bit rate is higher than 10Mb/s it will not play without buffering. You can convert the videos to a lower bit rate if this is the case.
