Is there a way to use the memory card to save recordings on? Or can you only save recordings on the clip zip itself and then transfer them to a computer?
If you are referring to FM or Voice recordings you do on the device itself then no, you cannot save the recordings directly to the external SD card. You can only save them to the internal memory. This is the way the device is programmed and it cannot be changed.
