When power is applied using a wall charger, the clip turns on. I’ve just noticed if you turn it off it no longer charges. Seems weird. The display turns off after a short time.
The Clips cpu monitors and controls the recharge. If the clip is off, it will not recharge. Do you have a sleep time set?
