Been using CJ for couple of years successfully. Recently when I plugged it into the USB port to charge it, instead of the usual display an image of a USB clip and the test “transferring” appeared on the display. Never seen it before. The thing is working okay except it does not seem to be charging. Any ideas out there?
Did you change the cable used to connect it?
