USB Flash Drive that support Mass Storage Class Ver 1.1
I would like to know if the sandisk 128GB USB flash Drive compliant to USB MSC Version 1.1?
If support, which model is it?
Thank you so much for your advise.
Regards,
Hong
:smiley:   Hi Hong,
Dear member of SanDisk Community, welcome.
If you are referring to _ USB MSC o USB Mass Storage _, ie “USB mass storage device class”, well, is a set of computing communications protocols, defined by the USB Implementers Forum, which makes a _ Universal Serial Bus _ (USB) device accessible to a host computing device and enables file transfers between the host and the USB device.
The USB 1.1, 2.0, 3.0 and 3.1 versions are compatible between them.
All SanDisk Pendrives (USB Flash Drives or UFD), are compatible with USB MSC protocol.
See: http://www.sandisk.com/products/usb/drives/
Enjoy!
Regards, Alfred.                                                            (Google translated)
Hi Cacho,
May I know what is the latest version of rhe MSC class currently?
As my instruments’ user manual stated that it only support MSC version 1.1.
:smiley:   Hi Hong,
Well…
I’m sorry, I do not understand your question…
Please, can you give more details of your problem?
For more certainty and for other ideas, also you can send the question to the _ Support Team: _ http://kb.sandisk.com/app/ask/
Hi Cacho,
I’m trying to choose a USB thumbdrive to use on my instrument.
In the user manual of my instrument, there is one specification stated as below:
“Mass storage devices that are compliant with USB Mass Storage Class Ver. 1.1”
This is why I trying to ask which USB Flash Drive SanDisk have comply to the above statement.
Thank you for your advise.
:smiley:   Hi Hong,
Well friend, yes, I answered in my post # 2 above.
The USB 1.1, 2.0, 3.0 and 3.1 versions, are compatible between them.
=> All USB Flash Drive, is compatible with USB 1.1.
And see and choose here: http://www.sandisk.com/products/usb/drives/
Enjoy!!!
Hi Alfred,
Noted.
        OK!!
                                          Alegría!!                                   Freude!!
        :smileyvery-happy:
                                             Joy!!                                          Joie!!
        Hallelujah!!
