hola buenas , a ver quien me puede echar una mano con este tema. tengo un usb flash ultra de 256 gb, tuve que formatearlo y una vez echo reinstale SECURE ACCESS BOVEDA. Cuando voy a arrancar el ejecutable de esta aplicacion me dice que esta aplicacion solo funciona en usb´s de sandisk, pero lo curioso es que el pendrive es de sandisk. Pero ahi no acaba la historia, si lo pongo en un puerto 2.0 funciona pero en un puerto 3.0 no. Pense que estaria mal o la unidad o mi puerto usb 3.0, pues ni una cosa ni la otra . Este pendrive funciona bien en otro puerto usb 3.0 de otro ordenador, asi que solo me quedaba saber si era el puerto el que estaba mal , pues pinche otro usb ultra de 128 gb que tengo en usb 3.0 y este funciona perfectamente. Alguien me puede dar una idea de que puede estar pasando?
I know this is an old conversation, but no one ever replied to this young man. I translated his questions so now maybe someone could possibly answer him.
hello good, to see who can give me a hand with this issue. I have a 256gb ultra usb flash, I had to format it and once I do it reinstall SECURE ACCESS BOVEDA. When I go to start the executable of this application it tells me that this application only works on sandisk usb’s, but the funny thing is that the pendrive is from sandisk. But the story does not end there, if I put it on a 2.0 port it works but not on a 3.0 port. I thought it would be wrong or the unit or my usb 3.0 port, because neither one thing nor the other. This pendrive works well in another USB 3.0 port of another computer, so I only wanted to know if it was the port that was wrong, then click another 128 GB ultra usb that I have in usb 3.0 and it works perfectly. Can someone give me an idea of what may be happening?
