Hi, I want to know before you buy if it will run smoothly on a usb 3.1 port with windows 7 sp1, thanks.
yes it should work
Hi Salu,
So, no problem friend. Enjoy!
USB 3.1: architecture maintains USB 2.0.
USB 3.1: will have backward compatibility with USB 2.0.
Your pendrive 3.0: in USB 3.1, will have speed USB 3.0.
Your pendrive 3.0: in USB 2.0, will have speed USB 2.0.
Regards, Alfred.
Just a heads up, make sure that your Windows 7 is updated to enjoy the optimum performance. ![]()
