Hi just buy a sandisk 32gb and copy a large files of mp3s in to usb with SanDisk SecureAccess software, when i connect the usb flash on to a different pc and try to copy the encrypted files into a folder on hard disk in windows the transfer is so so so slow, what must have to do?
Don’t use the Secure Access. Just use it as a regular flash drive, especially if all you’re doing is transferring .mp3 files. All that encryptiing and decrypting takes time.
Th reason of that being slow is because of the encryption going on there. The more security you have, then the slower it gets. If there’s nothing really needed, then I would skip using the secure access too.
