SecureAccess Support resource page and FAQ
SanDisk SecureAccess support information and download page
http://kb.sandisk.com/app/answers/detail/a_id/2399/
What is SecureAccess and where do I download the software?
SanDisk SecureAccess software is a fast, simple way to store and protect critical and sensitive files on any SanDisk USB flash drive.
Access to your private vault is protected by a personal password, and your files are automatically encrypted - so even if you share your SanDisk USB flash drive or it becomes lost or stolen, access to your files are safe.
Download SecureAccess:
For PC -  Download for PC (26MB)
For Mac -  Download for Mac (39MB)
Quick Start Guide:
- Download Quick Start Guide (pdf, 9MB)
FAQs
1. Does SecureAccess need to be installed on my computer?
2. What is SecureAccess Manager?
3. How do I remove SecureAccess on my flash drive?
4. Uninstalling SanDisk SecureAccess Manager
5. System requirements for SecureAccess
6. How do I check the version of SecureAccess?
7. How do I set up my SecureAccess account, file encryption etc?
8. Moving files into a “private folder” or “vault” using SecureAccess
9. How do I install SecureAccess on my flash drive using a Mac?
10. How do I install SecureAccess on my flash drive using a PC?
More SecureAccess answers
Hello I downloaded SecureAccess for windows but it says “Use SanDisk SecureAccess from an external SanDisk device”. I know there is a never version 2 and 3, but I need this version because I have files encrypted with this version. I am running from a sandisk USB 3 stick on windows 11. How to fix this problem?
put it on the USB/SDD/HDD etc that should If it does not get a Cruzer glide USB stick or 1 that says it has the software preinstalled
