i lost my wire
so in my stupid and retarded country there is no sandisk retailer (i buy mi fuze on amazon and then i import it to chile)
here i find this
2.0 USB Straight Data Cable for SanDisk Sansa View/Connect/E200 Series/C100/C200 Series
* 100% new high quality generic (non-OEM)
* Convenient extra USB Data Cable for Sandisk Sansa
* Simply plug the dock connector into your Sandisk Sansa, the USB connector into your PC and transfer music
* Cable can charge your Sandisk Sansa and transfer data at the same time.
* Update music,data, and more to your Sandisk Sansa through this data cable. Hotsync and charge your Sandisk Sansa at the same time
* For use with: Sandisk Sansa
* Compatible with model:
o Sansa Connect
o Sansa View
o Sansa e280
o Sansa e270
o Sansa e260
o Sansa e250
o Sansa e280R Rhapsody
o Sansa e270R Rhapsody
o Sansa e260R Rhapsody
o Sansa e250R Rhapsody
o Sansa c140
o Sansa c150
o Sansa c240
o Sansa c250
so the question is, is this wire compatible with the fuze???
thanks
and sorry for the bad engrish ahahahaha
