I have used the ref flash disk for a long time. It appear as an icon in My Computer (local disk) but is asking me to format it.
I can see it in Devices and Printers.
Is there anything wrong with the file system?
Is there a way to restore it?
in that case you can format the drive and see if after that its detected normally by the computer
Yes understand, but I would like to keep/restore my file on the USB…
See if running CHKDSK on it helps.
Does not work when file system is RAW…
Since we are grasping at straws try this:
Safely remove the USB drive, if possible.
Reboot the machine.
Once the reboot finishes insert the USB drive. Hopefully Windows will says there is a problem with the drive and offer to fix it. And hopefully the fix allows you to access your files on it.
Good luck. I hope it works.
I manage to recover via http://www.aidfile.com/
Very happy to hear you got your files back kstrid. I hope they were worth the $69.95 you paid for that app.
