USB 2.0 Cable | Where to Buy?
I lost the USB connector for my 4 Gb Clip so I can neither recharge nor connect to my computer.
Where can I buy a connector? I looked all over the website without success.
Thanks,
Steve
Thanks,
Steve
I use the company bagaincell.  They have their own website, but I usually get their products through amazon; as they are a reseller with them.  They offer the same products both places but if you go through amazon, the prices are better.
I wanted a longer usb 2.0 - mini cable myself and they had a nice 10ft one for $1.04 (US).  Just type in the search in amazon what you are looking for and if bargaincell isn’t the main company listed, just click on the alternate vendors on the listing page.
Of course, if you don’t like shopping online, or waiting for it to get shipped, you could try Radio Shack, Wal-mart, Best Buy, etc… stores that sell electronics usually have USB cables… I don’t know if you have one close by, but Dollar Tree has a few USB cables for $1.00, it just depends on if you want a name brand one or not. Personally, I’d try Best Buy first, If they’re too much, try Wal-Mart… Hope this helps!
Message Edited by magzbro92 on 03-16-2009 03:13 PM
Thanks for your help and suggestions.
Turns out I had a USB cable from a cameral which worked just fine. I was a bit hesitant, thinking there was something proprietary about Sansa’s but no problem.
I bought the Clip at Best Buy, but when I went there yesterday, it was like the locusts as been through. The Mp3 section was just about empty.
Steve (aka Lusophile)
