Is there anything I can do to get this old trusty card to function again? Thanks
Make sure that the card is not locked. You can also format the card on your computer then format it on your camera.
I did that but when I insert the card into the camera it tells me to format it but nothing happens. I’ll give it an other try.
I did again and this time it worked. I was NOT formating the card properly in the camera. Thanks again.
Awesome…
