U3 removal tool for MAC
BEFORE YOU BEGIN TO REMOVE U3 PLEASE BACK UP ALL OF YOUR DATA
MAC OS 10.4 and 10.5 supported
Download the U3 Cruzer Utilities for Mac by clicking the following link and save it to your Desktop:
Cruzer Utilities <– Download here
  1. Find the file named “cruzer-utilities-mac.dmg” on your Desktop and double click it.
  2. Double click the Cruzer Utilities installer.pkg file.
  3. Follow the installation wizard to complete the installation
  4. When prompted to Restart, click the Restart button.
  5. Once the computer has fully restarted, double click on your hard drive, and then double click on the Applications folder, then the Utilities folder.
  6. Inside the Utilities folder will be a SanDisk Cruzer folder, double click it.
You will see three applications:
Launchpad Removal Utility for MAC - removes the U3 LaunchPad.
Password Enabler-Disabler - allows you to use the Security feature of U3 to lock the drive and prevent unauthorized access.
Password Change - allows you to change the Security password that locks the drive.
There will also be a removal tool to uninstall the Cruzer Utilities which should only be used if you want to remove the three applications.
SEE BELOW FOR INSTRUCTIONS ON HOW TO USE EACH UTILITY
U3 Launchpad Removal
MAKE SURE YOU BACK UP ANY DATA THAT IS ON YOUR FLASH DRIVE
  1. Double click the Launchpad Removal Utility for MAC.
  2. When prompted, click Next.
  3. You will be asked if you want to restore your data, since you have already BACKED UP YOUR DATA, choose No.
  4. Click the Format button.
  5. The Launchpad will be removed and the drive will be formatted. It will give a progress bar and timer.
  6. Click the Done button to close the program.
  7. Copy your data back to the Cruzer.
Enable or Disable Security
  1. Double click the Password Enabler-Disabler utility. Depending on if a password has already been set, see below for the proper instructions.
(With no password currently set)
  1. Enter a new password of your choice.
  2. Retype the same password for verification.
  3. You may choose a hint question in case you forget your password. This is optional.
  4. You will now be prompted for a password every time you plug the Cruzer into any MAC that has these utilities installed. If the utilities are not installed on a MAC, you will not be able to access this flash drive. Functionality on a PC will not be effected.
(With a password currently set)
  1. Enter your current password and click OK.
  2. The drive is no longer password protected.
Change Password
  1. Double click on the Password Change utility.
  2. Enter your current password.
  3. Enter a new password.
  4. Type the new password again for verification
  5. You may choose a hint question in case you forget your password. This is optional.
  1. The cruzer utilities for mac only allow you to remove U3 or use the password protection. the U3 Launchpad will not function on MAC.
2. the only thing you would need this utility for is if your device is password protected.
  1. I was told by sandisk support that there is no plans for a Leopard update.
ornate party season again to come, u are also in feather hidden your figure whether you should risk a bubble,  holiday how can enjoy the dress well, especially ferial dress up the body, And only pursue is gorgeous, expensive is not important, the important is: oh you want to wear a belong to oneself style!
Then I came to help you dress up into the meeting of the Style.
 url=[http://www.newamytrade.com]air max shoes,air max 2009, air max 2010, only 58USD[/url]
url=[http://www.buyinb2c.com]cheap air jordan [/url]
url=[http://www.handbags-zone.com/]luxury handbags,discount designer handbags[/url]
Branded product, quality and cheap
If you will be undertaking on your desi gner handbag at wholesale prices company started out and as any Ni in your search through it all to acquire your products, url= [http://www.buyinb2c.com]cheap air jordan [/url], subsequently perhaps you might be Xiwang check SaleHoo. SaleHoo is certainly far more general public because of the World-wide-web, it entails providers to lower the important who owns a great back ground. In case you are searching for material, chances are you’ll purely always be surely looking for them. url= [http://www.handbags-zone.com/]luxury handbags,discount designer handbags[/url] This web site has long been authenticated customer, to make sure you are typically presented, mobile computer may be a well-performing enterprise, with your individuals at this point. That will as long as you are on the trail, expect might possibly establish in which as numerous terrific make use of ones own gross sales.
E-commerce platform
On another personally, in case you are a complete waste of a multitude of several hours with download in your very best usage of computers, url= [http://www.newamytrade…com]shox shoes,nike shox shoes,free shipping[/url],yet only positively have fun with the sport,juicy bags, perhaps you may like to apply in becoming further daring presenter Gucci totes at wholesale prices World wide web advertising,(http://www.handbags-zone.com)] fendi handbags,Handbags online,50% off, many of the advantageous.Even in the particular SaleHoo consumers by certification, you have to pick out thoroughly. Later many, this can be by which you would are given your revenue. (http://www.buyinb2c.com/discount-Gucci-High-Top-Have-Big-Size-1012-cheap-p-126003.html][/img)]
Ah, I see at least 1 spammer’s been busy this weekend. :angry:
Thanks a lot san,now I can safely remove it,The thing I forgot is the backup. Good thing I read this thread, So useful. :slight_smile:
Thanks for this guide. I’m sure a lot of MAC users will be able to benefit from this. It would also be nice though if this is added to the KB site as well.
You responded to a thread that is over 4 yrs old!  Why?
how can i format my ultra USB flash drive?
some kind of virus is in it, and i cant use more than a half of the storage
Use the MAC format function.
Hello sansamonsta,
Someone add my website wiknix.com to blacklist, but it completely safe. I not able to post with links. Please remove from blacklist. It’s safe (using HTTPS).
I think some of the bad guy, add my website to spam. But it’s safe.
Please solve my issue.
Thank You.
if you have any iPhone issues or facing any difficulties while accessing your iPhone you can visit our site for the total support. we will give you the solution for your particular issue.
https://iphonesupport.net/solve-common-iphone-errors/
Are you a music lover? Garageband’s have features which are everything you need to create your own music studio. If you have any problem regarding this visit http://sfy.co/garageband-pc/ We will help you.
If you want to remove the U3 for MAC then you can use the tools which you can get online or you can remove it by contacting the Apple iPad Repair Services
