What type or format of video are you attempting to convert? Most people find they have to first use another conversion software before running it through SMC for final conversion & transfer to their players.
OK, the fact that it is stopping at basically 50% means that it’s converting the videos, but it’s just not transferring them to the player (the other 50% of the procedure).
Are you doing this 1 file at a time, or several? I think I read where there’s a issue with the latest SMC and multiple file conversion. The work-around is to do them one at a time.
And you do have your Fuze connected, and a picture of it shows in the upper left-hand corner of the Converter under Device , doesn’t it?
The other possibility is (and don’t take this the wrong way, because it happened to me twice before I figured it out) that there’s not enough free memory on the device to hold the converted file. In my case, I was intending to put the video on my memory card and didn’t notice that the player was highlighted instead of the card icon. There wasn’t enough free space on the player, so same as you it would convert and the progress bar would go up to approx. 50% or so, then error out.
I’m doing this 1 file at a time. What’s the latest update on SMC, 4.236 ?
And yes, my Fuze is connected. I think the SMC itself laggs’ .
And I’ve read how much space I’ve got left.
So far I have over a 100 songs but under 200 songs.
I currently have 2 videos also.
Total Space: 1929.2MB
Availabe Space: 1191.3MB
I should have enough space for videos on the MP3.
Does this mean I can’t add anymore videos to the MP3.
And I think it’s a bit risky if I delete those 2 current videos and add another video for a test drive, I’m afraid it might not give me those videos. :[
I need more help in this please.
I mean it will be way easier if videos are easy to sync into the MP3 like songs are.
I tried using Media player and syncing the Video to the Mp3.
The video is on the mp3 but it doesn’t appear in the mp3 only through computer files.
Is there a way where videos can just sync into this Mp3 just like that?
There’s no way to ‘sync’ videos to your player through WMP or any other media player. They HAVE to go through the SMC.
I’d try running them through another converter program first and then seeing if SMC can handle it. Any Video Converter (yes, that’s the name of it) has been recommended by several people here and it’s free.
You don’t have anything to lose, and it might work.
You might try WinFF (Google it) and create a new preset as described in this post. Don’t worry about it being a setting of the e200v2 models. The Fuze is the same as far as this goes. Further down the thread is another worthy program, Avidemux that can help with any audio sync issues.
I’ve been using this before final conversion and transfer with SMC quite successfully. The converted videos play fine on both my e280v2 and my Fuze.
How many videos have you tried since the beginning of this discussion? Sometimes even Anydvdconverter that I bought doesn’t convert movie dvd’s (and these are not the brand new ones). It works about 95% of the time. Then SMC works about 97% of the time.
Have you tried other videos?
Maybe it’s some of the youtube videos, even though some work, some may not, just like the DVD’s I’ve tried.
