This has to have been asked before but I cannot find it. Sorry, I did try.
How can I just hook my Fuze to the computer and synch everything to the player? I have 12GB of music and WMP and MM both see 2 drives. So I have been manually loading part of it to each, the player and the card. Well I did it in MSC mode and am now missing a ton of album art. So I just want to do it again.
Possible to just SYNCH ALL> in one fell swoop???
O, yea… I guess I could do that. I could do that in MTP mode, as well.
duh!
Some of my tracks must not have the album art in the file because I did do xfers with MSC and am missing a TON of album art. Probably missing 40%.
Anyway to check if the art is in the file?? There will be a seperate folder.jpg if it isn’t, right?
Thanks Martian.
duh!
Thanks Martian.
If you use WMP to load your music, in MSC, the art doesn’t like to transfer. That’s why I bypass it by drag and drop(or copy and paste) . All my music has the seperate folder .jpg visible right there in My Computer.
