The disc is write protected!
I am using this 32 gb cruzer blade flash drive.
I tried to edit the info inside but it’s keep prompting.
‘The disc is write protected!!’
May I know how to unlock it!
I can’t even format or do anything on it!
Does it’s means my drive is no longer able to use?
Thanks
Most probably this is already a hardware issue. I hope you still have warranty on this. You should check out on how to do RMA on this. <img src=“https://imagicon.info/cat/5-43/16x16\_smiley-happy.gif”/>
