Just added 3 albums. All properly tagged in mp3tag. Everything fine.
Three days later, turn on fuze, now there are six versions of the artist displayed…each with a typo or a chinese character after the artist name. Any idea how this could happen? Rebooting does not help. No other issues like this. Fuze V1.01.22A
I have not yet checked the albums with mp3tag again to see what they look like there. I suspect they are fine and the fuze is making some issues…but I suppose I should check that.
Should add that one of the three albums is FLAC and I tagged it up using mp3tag…this did not seem to present any problems at the time.
Any ideas?
Any ideas?
I never bothered with FLAC on my Sansas, so I can’t speak to that album. As far as the others, look at them again in MP3Tag on the player, just to see…but I’ve found that once I get all my tags set up the way I want, that setting them to read-only before adding them to the rest of my library seems to keep them from being corrupted. Give it a shot!
Thanks MM. Never realized that was an option. This is the first time this has happened in about three years. I looked at the files on the Fuze with mp3tag and some artist names fields were corrupted with a character at the end of the name. The Fuze was also pulling the actual file name and putting it up as the song name. Ex: The filename 01.Beatles-Abbey Road-Something.mp3 would show up as the name of the song instead of “Something”…and even this sporadically. Only one of the albums had corruption.
I pulled them all off and added fresh copies. Weird. Fuze has a mind of its own. I will try the “read only” next time I’m using mp3tag.
Just to clarify…it’s not something I do in MP3Tag…I do that in Windows Explorer/My Computer. Highlight the folder , right-click, hit “properties” and then select read-only, and apply it. That should keep the tags the way you like them.
