Strange behavior on my USB
Hello. I have been using a SanDisk Ultra USB 3.0 256GB USB as extra storage for the better part of 3 years and it’s worked like a charm but the past week or so it has been acting rather strange. Initially it would let me access the files but then it would hit me with Cyclic Redundancy Error. My computer would boot up terribly slow with it plugged in. I tried to use chkdsk to attempt to clean any errors but it would hit me with the “cannot open volume for direct access” I would have moved the files to a recently cleared portion on my hard drive but the holidays got in the way and yesterday my computer straight up would not let me view any of the files with it plugged in. The slow boot up turned to frozen boot up. I tried to restart my computer last night and it wouldn’t do so with it plugged in. When it’s plugged in, Windows Explorer is unable to do anything if I click on the drive. I understand that one shouldn’t pull it out while it’s “in use” but I take it out and the computer does what I tell it to do. I’m confused at how a USB can make my computer act like that. The files weren’t too important so I’m not bothered if it’s a total loss.
The drive is a SanDisk Ultra USB 3.0 256 GB KCC-REM-TAD-SDCZ48 BQ2202001185W SDCZ48-256G if that helps it. My drivers are all up to date and my other flash drives work okay
Hi @ActilePep ,
The first thing to do is check for CRC (Cyclic Redundancy Check) errors, as these indicate data corruption during read/write operations, mainly explaining the slow access and file errors. Try updating the drivers and run chkdsk to fix such issues.
I tried to use chkdsk to attempt to clean any errors but it would hit me with the “cannot open volume for direct access” and all my drivers are all updated
The “cannot open volume for direct access” error typically occurs when you try to run chkdsk on a drive that is currently in use or is mounted. To successfully run chkdsk, you should run when the drive is not actively in use. Also, try to run the chkdsk in Administrator mode only.
Hi and Hello:
I am new to the SanDisk Forum and guess what? I have the same problem.
I cannot gain access to the needed file in the vault. My desktop with “my PC” will show my C:\ volume with folders and files but the SanDisk Volume F: only shows the USB drive, disk “F” and NO capacity in use and/or the files that are associated with this drive.
I should have realized I was in trouble with many occurrences of CRC errors shown for the drive prior to my issue now which is “dead USB drive” with password on board (strong) and encrypted files.
Is there a backdoored access from San Disk?? i am afraid I am hosed.
Comments?? Recommendations??
2 suggestions:
  1. After booting, insert the USB drive, then run a chkdsk /f command for the drive.
  2. For important files, maintain a backup somewhere.
The error “chkdsk cannot open volume for direct access” usually occurs when the drive is in use or locked by another process, or if the drive is damaged in a way that prevents it from being accessed. Check out this article to learn more how to fix the “chkdsk cannot open volume for direct access” issue. However, you should know that no storage device lasts forever. A dead drive may be beyond repair and simply need replacing.
It seems like your SanDisk USB drive is facing file system corruption or hardware failure. You can try plugging it into another computer or USB port to check if the issue persists. Use data recovery software if the files are important, or try running chkdsk from Command Prompt. If it doesn’t work, consider formatting the drive, though this will erase all data. If the problem continues, the drive may need replacing.
It definitely sounds like your SanDisk USB drive is experiencing hardware failure, possibly at the controller or NAND level. The symptoms you’re describing — CRC (Cyclic Redundancy Check) errors, system slowdowns and freezes when the USB is connected, inability to access the volume using chkdsk, and Windows Explorer becoming unresponsive — all strongly suggest that the drive is either failing or has already failed. You may need to format the disk to fix the problem.
You can check this guide to find detailed solutions to fix Chkdsk cannot open volume for direct access
The error should have been caused by data corruption, hardware damage, or issues with disk sectors. You can try using the error-checking feature in Windows to see if it can resolve the issue.
https://www.dell.com/support/kbdoc/en-tj/000148643/using-the-chkdsk-utility
If you still need to recover important files from it, you can try cloning the drive first. Afterward, use Diskpart command lines to clean all data from your USB drive and fix any logical issues.
Related: How to fix data error cyclic redundancy check and recover lost data?
