I recently had my SSD Plus go dead on me.
The message I am getting is ‘Check cable connection!. PXE-M0F: Exiting Intel PXE ROM’
I took the SSD out and put in the old hard drive. The laptop works fine with the HDD, so the problem lies with the Sandisk SSD.
I took the laptop with the SSD install to a true ‘Microsoft Store’ hoping that it was just Windows that was correupted.
They did some diagnostics and said the SSD passes all the diagnostics, however, the partition tables are RAW (what ever that means). Microsoft said there are bits and pieces of data that could be recovered, however, they are only portions of entire files.
I’ve only had this SSD for a year in my laptop, and now this ?
Any ideas on what to do next ? MS says the SSD passes its diagnostics, but they also realize it doesn’t work !!
