ssd dashboard isnt reconizing my Ultra 3D SanDisk SDSSDH3-1T00-G25
its showing it as a X600 SSD help
the X600 is the OEM 3D nand ssd sandisk. The Ultra 3D is probably buildt with the same technology This is probably just a incorrect detection of the ssd. I would not worry about it too much.
https://www.sandisk.com/business/computing/x600
I did report this to sandisk support so they can look into it as well.
ok but is there a fireware update for my ultra 3D or if there is will it even detect it even tho the dashboard failed to recongise the ssd model
Thanks!
Chris.
