SSD advice needed; WD vs Samsung vs SanDisk, quality-wise
Hello everyone,
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest).
I know the price is relevant to the different technical specs, but…
From your knowledge & experience, are Samsung and SanDisk good enough to trust them with my precious data?
I would have certainly gone for WD Blue, but there’s a good price difference (with similar specs to the other two brands).
What do you recommend?
Thanks
Check this awesome app cyberflix tv
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest). I know the price is relevant to the different technical specs, but… From your knowledge & experience, are Samsung and SanDisk good enough to trust them with my precious data? I would have certainly gone for WD Blue, but there’s a good price difference (with similar specs to the other two brands). What do you recommend?
 UC Browser SHAREit Appvn
my issue has been solved
