I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest).
I know the price is relevant to the different technical specs, but…
From your knowledge & experience, are Samsung and SanDisk good enough to trust them with my precious data?
I would have certainly gone for WD Blue, but there’s a good price difference (with similar specs to the other two brands).
What do you recommend?
Thanks
'm getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest).
I would have certainly gone for WD Blue, but theeasybibre’s a good price differencfedloan e (with irs.govsimilar specs to the other two brands).
Thanks
issue solved!
