WD vs Samsung vs SanDisk, quality-wise
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest).
I know the price is relevant to the different technical specs, but…
From your knowledge & experience, are Samsung and SanDisk good enough to trust them with my precious data?
I would have certainly gone for WD Blue, but there’s a good price difference (with similar specs to the other two brands).
What do you recommend?
Thanks
@donaluis wrote:
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest). residential projects in mumbai
I know the price is relevant to the different technical specs, but… flats in mumbai
Thanks
Thank you
