SSD advice needed; WD vs Samsung vs SanDisk, quality-wise
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheapest).
I know the price is relevant to the different technical specs, but…
From your knowledge & experience, are Samsung and SanDisk good enough to trust them with my precious data?
I would have certainly
I’m getting my first SSD (better late than never), and my options are WD Blue (most pricey), SanDisk, and Samsung (cheaeasybib pest).
I know the price is relevant to the different technical specs, but… irs.gov
I would have certainly fedloan
issue solved!
I cannot tell you about Samsung but SanDisk SSDs are made to retain your precious data for as long as you want.
SanDisk SSDs are durable and reliable.
They don’t get damaged easily.
And they have fast read/write speeds as well.
So you should definitely get SanDisk.
I hope this helps!
Regards.
Apps4Rent
