IM NEW HERE… Need help
re: Sansa c250… ez to use, but when i plug the player into my car jack the sound is not loud enuff . can anyone help me… >???
you dont really have to type the subject line in all caps, we can all see it just fine.
If the sound is all the way up, and you have already toyed with the equalizer, theres nothing you can do about it in regards to the c200. Turn up the radio in your car, if you tried that… your car system needs work, cuz im sure if you plug in headphones, its plenty loud enough.
go to Options > volume > and set high
