I purchased the cord to connect my mp3 to the stereo. The sound is not very good and I’m curious if others have done this and with what results? Possibly it’s something I’ve done wrong? Thanks
You have to set the volume on the player most (if not all) the way up, and then use the volume on the stereo to control the final output. Remember these little things are only designed to drive teeny-weeny earbuds or headphones and only put out milli-watts of power. The amp in your stereo will have to carry the rest of the load.
having the same problem.![]()
I copied and pasted the url- took me to Ask but I didn’t see anything pertaining to the problem. But thanks, paul
@miikerman wrote:
[The link 2 posts above simply is spam . . . .]
Nooo! . . . Spam? . . . Here?
I’m shocked!
Make sure the volume cap isn’t on or you’ll have trouble driving a stereo.
How do I make sure about a volume cap- I have no idea what that is. Thanks
Are you in the EU, if so you probably have it. Check the forums, theres tons of info about checking for it and removing it.
I have it- thanks for all the help-GREAT!!!
